D Dougdog084 New Member Jun 16, 2009 #1 I know that I have to use the ex harness and wire for the ckf sensor but the obd 2 jdm gsr has a diffrent dizzy connector the ecu is a jdm p72 thanks
N namoper New Member Jun 17, 2009 #3 you'll have an 8pin dissy connector on your ex loom and your gsr dizzy will have 2 plugs. You can get a conversion harness from rywire for around $40.
