b18c into ek mount question
Discussion in 'Civic and del Sol - EG and EK' started by ruskisky, Jun 8, 2011.
  1. ruskisky
    ruskisky New Member
    so i'm looking to swap a jdm b18c into my 98 ex 5spd.
    this whole "which mount to buy" is bugging me (i'm sure it's easy, i'm overthinking maybe??)
    based from this link: http://hondaswap.com/swap-articles/6th-gen-civic-basic-swap-overview-29118/
    i only need to buy two additional mounts? the rear tranny mount and drivers side mount? i can't figure out which mounts to actually purchase from this:
    Honda Automotive Parts
    i would just re use the other mounts? please explain further in depth if you can, and i'm not trying to buy hasport/innovative mounts if i can use oem.
  2. Matts96HB
    Matts96HB . Moderator VIP
    you need the tranny mount (whole thing)
    the driver's side upper mount
    and the rear t-bracket
    so, youll need the following:
    1 #7
    1 #6
    and i think 1 #4, but i cant honestly tell from the picture. you need the upper portion that goes from the mount on the engine to the top of the rubber on the chassis, but i think you have to buy the whole damn thing judging from that picture.
    and yes, youll re-use the other mounts provided they are in good condition.
  3. 93hatchie
    93hatchie New Member
    Stock mount will fit tranny mount, tripod mount on driver side should be the same, the rear mount from a 99 si. Hope it helps.
  4. rhymeshark916
    rhymeshark916 New Member
    Sacramento, CA
