B18C swap
Discussion in 'HYBRID -> EG-EK / DC' started by EG6_down5hift, Mar 11, 2004.
  1. EG6_down5hift
    EG6_down5hift Junior Member
    if i bought a OBD1 JDM B18C gsr, would i need a USDM GSR wiring harness? I heard a 92-95 civic ex/si harness will do. The car is a 94 civic dx hatch. Will the civic mount bolt the GSR? (i know i have to wire VTEC and Knock)
    The IAB i heard, can be vaccuumed off somewhere, so it'll eliminate the secondary butterflies to function and get vtec better? how would i do that?
  2. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    don't eliminate the IAB's. If you do, all that will happen is you will lose low end torque and your VTEC will bog slightly when it first switches over @ 4400
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    do you mean what mounts?
    As for wiring, you may have to legnthen some of the harnesses, but there should only be 6 or 7 wires that you have to run, and they are all in one of our swap articles.
  4. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    :concur: and you don't wanna drop the IAB homie, if you're not interesting in wiring for it then buy a skunk2 manifold
