B18c Type R Con Rods
Discussion in 'Engine Building' started by integraR, Jan 3, 2003.
  1. integraR
    integraR Junior Member
    Malta, EUROPE
    :rolleyes: If I keep my standard B18C Type R con rods but change to 84mm forged pistons (with resleeved block) how much nitrous can the engine take without breaking the con rods?
    Also if I change the con rod bolts to ARP bolts will they withstand more nitro?
    Thanks
  2. gtpilot
    gtpilot Member
    The ARP Rod Bolts will be a help if you are spinning the motor up tighter than stock numbers, but won't be of help with the NO2 - their purpose is to keep the bearing cap attached to the rod when the piston changes direction from going up to going down @ TDC.
    Someone else will have to vouch for the overall strength of the rod...
    Kirk
  3. cws13
    cws13 Senior Member
    Athens,GA
    If your sleeving your block I am assuming that you or your engine builder are going for big horsepower. No, your rods will come to a horrible end. Why would you spend 1300-1500 on a built bottom end and skip rods anyway? :huh:
  4. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    nitrous + stock rods =
