Swapping a B18C using a B16A1 engine harness and a B18A ECU harness into a DA6. The B16A1 harness has all the VTEC wires, I just need to know which ones they are so that I can run them through the B18A ECU harness and into the correct ECU terminal. Can anyone tell me what connector slot from the B16A1 harness I need to plug into to operate the VTEC solenoid + pressure switch, and knock sensor?
Please note that Hondaswap, Hybrid does NOT list this information (Ive searched). Basically if anyone has the B16A1 Shop Manual, that would help.
