I have about 3k on my rebuild, everything else is ok. The engine will not fire after the engine is at normal temp. If you have to make several stops, after the 2nd stop it will crank fine, but will not run. It can be push started VERY easy! What is by-passed when push starting rather than cranking? I think the master relay is ???
