i want to know if im going to have to buy after market mounts in order for the swap to be done...after market mounts from hasport, or can i just use some 99-00 si mounts...thanks for the help guys
well... the motor is obd 1 and the car is obd 1 correct? 92-95 civic's are obd1 so the wiring should be pretty simple. i just want to make sure on the mounts so i dont run into any big problems. so if anyone can share their knowlege on the subject to reassure me it will be great. thanks
if you swap a B series into a 92-95 all you need is the stock mounts from the Integra? Or what, Im so damn lost on this, I know on EF's you have to purchase aftermarket mounts from HCP or similar places, but with 92+ you can use 96+ Si's mounts?
