Originally posted by revolution8k@Dec 26 2003, 11:53 PM
Yeah and the Chiltons should take that into account and tell you which bearing goes on which bank.
Originally posted by arpee79@Dec 26 2003, 11:57 PM
I have the "B16 1994 Del Sol service manual" but i dont know if it works for a GS-R B18C1 ..
And should i get the MAin crank & Rod bearings from A)honda dealer ,B) the ACura Dealer or C) it doesnt matter there the same bearings
Originally posted by theB16tegguy+Dec 26 2003, 11:58 PM-->revolution8k@Dec 26 2003, 11:53 PM
again....... NO...... the banks take all the same color. And chiltons has no idea which one you have.
Originally posted by arpee79@Dec 27 2003, 12:11 AM
I see no color on the caps ,he said only the bearings where diffrent colors 2 green 2 yellow 1 black ok this solve the Main bearing PRoBLem execpt for the order..
I think C = Green ....D=yellow B=Black
now the CDCDB start from the water pump side and end facing the Flywheel.
Im 75 percent sure this is the way it goes.. rod bearings should be all the same color.
Now i need to find out the Rod Bearing Colors and Order.
