b18c1 N/A building!
Discussion in 'Engine Building' started by ovus07, Jun 11, 2008.
  1. ovus07
    ovus07 b18c1 redcoupe.
    somewhere in MD.
    hey! i just swaped an b18c1on my 93 civic coupe, i`m want to build it for N/A but i just have 5K buget. So, i was tinking just do the head work. i mean, build the head first.
    can anyone give me an advise about what parts should i buy? i mean which ones are good. and wich ones will be a waste of money.
    i would like to reach the 250 whp N/A but i know it can take more money.
  2. newb
    newb phresh VIP
    Backwoods Northwest
  3. ovus07
    somewhere in MD.
  4. Matts96HB
    Matts96HB . Moderator VIP
    If you want 250 whp and have 5k to spend get a decent turbo setup going and save the rest of the money.
    Its not logical to chase 250whp N/A unless you're really trying to prove something. Much more logical to go FI.
  5. ovus07
    somewhere in MD.
    actually i was thinking the same, i know that N/A set up will cost a lot and i wont get the power i want.
  6. ovus07
    somewhere in MD.
    now i changed my mind, and my goal will be 300 hp FI, of course. there is a friend of mine that will sell me a t t3/t4 turbo, ( used) it comes with a turbo manifold, intercooler and wastegate. so i still have to buy the intercooler piping and other stuff. but the turbo manifold comes from a b16, so idk if it will fit to the b18c1.
  7. Matts96HB
    Any B-Series manifold will fit.
    Now, as far as the turbo setup.. you need to be careful here and choose your parts carefully. If you don't, you could end up with something that will crap out on you, or something that doesn't make the power you want when you want it.
    For your goal (300 whp) I'd say go with a 60-1 turbo. Quick spool time, and will make that kind of power all day. GSR's have been known to be very strong engines, but upgrading the internals for FI is always recommended. It just increases the longevity of the engine, no matter how you look at it. Especially if your engine has alot of miles on it, new internals are recommended. AT LEAST go through the engine and replace the bearings, seals, etc.
    Good luck :thumbsup:
  8. ovus07
    somewhere in MD.
    hey thanx for the advice, i appreciate it. and yes i have to change some internals, my ingine has almost 140k miles on it, so i don`t wanna blow it out.
    Like most of you guys, i love Honda engines and i`m trying to understand them a lit better everyday, and i have to thanx to you all for been patients with guys like me. (noobes) hahahha
  9. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    That is quite the informative thread, newb. :D
    To the OP, are you planning on getting any type of work done on your head such as a PnP? Also, do you have any idea what parts you are wanting to use for your goals?
    If I may suggest, you could start a bit smaller and work on it piece by piece and take your time. Is this your DD?
  10. ovus07
    somewhere in MD.
    well, i was thinking on just get the valve train from Crower, (valve spring and TI retainers), i`ve read that the gsr cams will be fine for FI. (at least for my goals, but idk) and get some ARP head studs and get a thiker head gasket
    nothing of PnP, not yet.
    and yes it is my DD. and i figured out that i better build it up for turbo first.
  11. ovus07
    somewhere in MD.
    and i know that forget piston are neccesary and rods as well.
  12. Luis998
    Orlando, Florida
    I'm not sure if you are aware of this, but there is no "building it up first" for anything. You either build for boost or build for n/a.
  13. ovus07
    somewhere in MD.
    :oops: , i think i better start to learn how to write rather than build something.:lol:
    But that`s why i`m here, to learn something from the pro.
    note: thanx for have corrected what i wrote.
  14. Luis998
    Orlando, Florida
    No worries. :D Now then, I HIGHLY recommend using the "search" feature and looking around the forums for information on your goals and build.
    If you have any further questions about your head build, AFTER you do your research...and read the B16 head build thread that newb posted, which happens to be my thread, please ask.
    People on here will usually scold you if you do not do your research first and ask questions later. It's the smart thing to do. Besides that, if you don't do your research, you may end up buying things you don't need for your build and wasting your money as well.
  15. ovus07
    somewhere in MD.
    I already started to do my homework. I`m sure i will find everything i need to know, and then as you say, i will ask what you all think about my proyect. (when i `m clear of what i will use)
    thanks for everything!
  16. Luis998
    Orlando, Florida
  17. Matts96HB
    Research is key. But I'll give you a pointer right now. For your power goal, and knowledge level, a turbo kit is your best bet. They are pieced together for you and will get you to that goal.
    That way you can learn what each part of the kit does, and piece together your own later on down the road :D
  18. Ryma
    Ryma Member
    Theres a feller on team integra that built a gsr for all motor and made like 270hp or some jazz like that.
  19. efhondakid
    Akron-Canton, Ohio
    With a wallet as thick as a dictionary though, its just not practical for average Joe import builder to make that much in an N/A application.
  20. Matts96HB
    Right, and im sure he spent 10k+ to get there.
    This is a 5k budget.
