b18c1 out of eg chassis
gonzo_gsr
I'm trying to take a b18c1 out of my eg chassis and put it into another. I have a lot of info on removing the d16, but I was wondering if I could do anything differently w/ the b18 that would make easier. Thanks
Just be sure to remove the radiator, this will surely get damaged if you don't pull it first. Other then that it's pretty mutch the same.
:withstupid:
take the radiator out and just unclip the harness from the shock towers ... it will be easier to F with when the engine is out
be careful removing the drivers axle from the intermediate shaft, if you pull it too hard it will hyper extend, and then you are fucked. trust me ive done it before
