B18C1 swap into 95 Civic Dx
95CivicGS-R
Found out the B18C1 is from a 1999 Acura Integra and was running off a P30 ecu with a MSD ignition and V-con vtec controller in another 95 Civic dx. All my research is telling me to invest in a P72 ecu and to bag the vtec controller and to go with a Hondata chip, curious to know if anyone has seen a P30 ecu with a B18C1 before? I am a noob trying to help the husband if you have any ideas please let me know.
help the husband? and if the p30 worked with all that stuff and that motor then i doint see why not?
You could go with the P30, or go the tried and trusted route and stick with an OBD1 GSR ECU, that way you won't have to change a thing. If this is your first swap just get it running for starters and go from there. Much easier to do it that way.
