B18C1 swap into a 1999 EK Coupe
Discussion in 'HYBRID -> EG-EK / DC' started by 99d16z6, Feb 20, 2012.
  1. 99d16z6
    99d16z6 New Member
    Hey hows it going everyone. I have a few questions. Ive been looking into gettin a b18c1, and I was wondering with the correct motor mounts, could the b18 fit correctly in my 99 ek coupe? Also what computer would the b18 run off of P72 or P73? Thanks again.
  2. yps689
    yps689 New Member
    You can use your original driver and tranny mounts and you'll have to us the em1's t-bracket for the rear. I would go with a obd2a p72 or a obd1 p72/28 cause I believe the obd2b teg ecus have a code or some sort that kills the ignition.. correct me if im wrong..
  3. x5crunchy5x
    x5crunchy5x New Member
    use a obd2 p72 ecu it wiilll run good
  4. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    OBD2A ecu not OBD2B (immobilizer)
  5. 99d16z6
    99d16z6 New Member
    Thanks for the help guys i appreciate it....
