B18c1 Swap Into My Civic Questions
Discussion in 'Civic and del Sol - EG and EK' started by BIGJOSEPH, Jan 16, 2008.
  1. BIGJOSEPH
    BIGJOSEPH Big Joseph
    G-town VA
    Hey I Have A 1993 Civic Dx Non Vtech And I Am Looking To Do A B18c1 Gsr Swat Into It, The Kit Im Looking At Has The Motor Trans, Ecu, Axles, Ac Compressor, Alternator, Distributor, Intake And Everthing, I Was Wondering What Kind Of Harness I Need To Work The Vtech Since Mine Does Not Have It Now, And Also What Else Will I Need Besides Motor Mounts Shifter Linkage And Exhaust, Thanks
  2. ls/vtechatch91
    ls/vtechatch91 New Member
    washington
    u wouldnt need to change the harness.. just find the right pinouts on the ecu harness then run the vtec wires....
  3. Team_Asterisk
    Team_Asterisk R0T0R WH0R3
    Umm, dude...before doing an engine swap, do you perhaps want to figure out your typing? I mean, you capitalized like, EVERY word regardless if it needed it or not! Anyway, good luck with the swap, I hope it works out!
  4. BIGJOSEPH
    G-town VA
    for the most part it is just a simple swap most of it is just plug in and a few splices and is there anything else that i should take note of.
    thanks
  5. BIGJOSEPH
    G-town VA
    and also can you run ac after you install the swap the clearances look pretty close.
  6. get0nslimslevel
    get0nslimslevel DA BUSINESS AUTO CLUB
    PA
    it Does Fit But Do You Really Need A/c That Bad?
  7. BIGJOSEPH
    G-town VA
    I Guess Not But It Would Be Nice, Is It A Pretty Simple Job I Am More Of A V8 And Truck Guy
  8. BrutalB83
    Rochester Hills, MI
    Is the capitalizing of every word really necessary? Oh, and it's "VTEC", not "Vtech".
  9. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    Lol, people here are so sensitive of the Vtec spelling.
    Yes, it's just a bolt-in swap. Easy. You only need what you said, motor, tranny, ecu, mounts, axels, linkage, etc. It all bolts right up. The vtec wires you can either run yourself, or you can buy a vtec subharness from Rywire - Online Store .
    I'm 16 and I just did a D2D swap my first one and it came out great just have to wire up Vtec and I'm finished. Just to give you an idea of how simple it is, that's the first time I ever did more on a car than an oil change or a brake pad. And if you need any help, there's plenty of engine swap write-ups on this site and more.
  10. BrutalB83
    Rochester Hills, MI
    Who you callin' sensitive, biotch?!? :p
    Anyway, I think it's justified. VTEC is an acronym, every letter stands for something. The T-E-C isn't meant to be read as "tech", but that's how everyone seems to think it works. I just think that if these people actually hope to successfully tune their Honda cars, they should at least know basic things like this...
  11. BIGJOSEPH
    G-town VA
    Thanks For The Help 93civic Racer.
  12. BIGJOSEPH
    G-town VA
    O And Where Is Work The Computer Stays On Caps Unless You Hold Shift Key To Undercase It And Its Not Worth Holding It To Me
  13. BIGJOSEPH
    G-town VA
    also i was considering putting the skunk2 intake manifold on the gsr and it says a little modifieng required i was wondering if anyone knew what needed to be modified, and also i was going to put cam geers injectors and what size throttle body should i put.
