b18c1 vs b17
Discussion in 'Integra' started by DAallday, Apr 1, 2008.
  1. DAallday
    DAallday New Member
    I've heard that a b17 is faster than a b18c1 gsr. can anyone tell me their input. i know that the b18c1 has more hp and torque but the b17 has a shorter geared tranny. i'm trying to figure out which is faster?
  2. Uncle Buck
    Uncle Buck JDMDecals.com guru
    Spearfish, South Dakota
    shorter gears can make all the difference in the world.....
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if the motor is in the same car the b18c1 gsr motor should be faster. but if your talking about 1993 gsr vs 1994 gsr the 93 will win, because the da was the fastest integra to come to the states
  4. BrutalB83
    Rochester Hills, MI
    It depends on what motor/tranny combo you're talking about. If you're using the same transmission on both motors then the B18C1...
  5. DAallday
    DAallday New Member
    what if its a b17 with the b17 tranny and a b18c1 with the b16 tranny?
  6. BrutalB83
    Rochester Hills, MI
    The B18C1 would probably take it. The gear ratios are actually listed in one of the FAQ articles on this site, let me see if I can find them...
  7. BrutalB83
    Rochester Hills, MI
  8. DAallday
    DAallday New Member
    how would i know if the b16 tranny had that final drive?
  9. BrutalB83
    Rochester Hills, MI
    Look for the code on the transmission. Avoid the Y1. Actually, you'd probably want to avoid anything pre-92 anyway, since they switched to hydraulic actuation in 92, at least for Civics. For Integras they switched to hydro in 94.
    What kind of car is this going into?
  10. DAallday
    DAallday New Member
    its a 98 gsr going into a 93 integra.
  11. 92civicb18b1
    92civicb18b1 The Trisexual
    Remember a b16 trans is going to put you at rather high RPMs at highway speeds. Some people complain about it.......
  12. DAallday
    DAallday New Member
    yeah. i'm not really worried about the high rpms...considering i really don't drive on the highway. i'm just trying to figure out what i need to do for this swap. wireing, and etc...
  13. BrutalB83
    Rochester Hills, MI
    Ah, ok. You're actually going to want a cable-actuated transmission then. Either that or you'll need a conversion kit.
  14. DAallday
    DAallday New Member
    alright. and will this engine just bolt right up?? what about the wireing??
