B18C1 vs. B18C5 what is the difference
If your going to boost don't raise the compression over 9.0:1 / If you do your going to have to run meth injection or race gas depending on boost levels, cause the higher compression ratio the more octane you need to slow the burn inside the combustion chamber. If you run lean your actually raising cylinder temperatures cause a evil person called detonation to fuck your life & your wallet up!!!
This thread is 9 years old
