B18C5 in a 1987 CRX Si
syk
Is it possible and how much am I looking at here.
yes it is poss. but you better have lots of money and/or a complete donor car. the easiest way would be to take everything from the donor and put it in your crx, and I mean everything from the motor to the gauge cluster. but realisticly you will just need lots and lots of money.
ok i can get a b18c5 for and installed for a total of $6,000 with hasport mounts and harness and hondata ecu. is this a good deal or am i going to need more?
it will be a really tight fit but it can work, by tight i mean u might have to do some cutting and welding but it can work.
