b18c5 in ek3 civic
civic booster
have not started yet but jus wanna know if i can jus plug in the b18 ecu into my dash, or do i have to add wires,splint or replace how easy is it (the original engine was a d15y7 non vtec...) any feedback wud b appriciated..can i get any step by step procedure for the wiring (any links).. im gonna do most of the mechanical work myself but not to keen on the wiring and dont want to trust any one to wire cuz i want this project to be done neatly and properly...thanks
if you use an obd2a ecu it will just plug in, except you need to add the wires for vtec. You can't use any obd2b ecu(99-01) only obd2a(96-98).
will a 1.4 ek3 civic dash loom run a 1.8 sir integra engine using 1.6 vti ek civic engine loom
not sure on obd2 i have only wired up obd1 vtec.. someone else here should know..
