B18c5 into 1999 EK4
Dave_yd
hi from england,
There isn't much advice on english forums regarding this conversion, basically i need to know what electrical parts i need, i kno my car is OBD2B, wiill i need a conversion harness? also what ecu do i run? and do i need to wire anything up? i can physically put the engine in i just need to know aht i need for it to run? also will the ek4 fuel pump be okay.
thanks alot
Dave
should plug right in.. they are both same obd if you got the c5 from a 2000-2001 type r.. if its from the 97-98 you'll need the obd2b-obd2a conversion harness
rite,
i kno what im doing now, i plan to use a p28 ecu with crome put on it then an itr basemap, i will use the b16 engine loom and convert the harness from OBD2B-> OBD1, that will do away with the secondary 02 sensor and knock sensor, that sound good peeps?
