B18c5 Into 94 Civic Ex
Discussion in 'HYBRID -> EG-EK / DC' started by EF9Civic, Mar 27, 2003.
  1. EF9Civic
    EF9Civic Junior Member
    I just recently purchase a 99 Integra Type R wrecked in the rear for cheap and I'm planning to swap the motor into my 94 Civic EX. I was wondering what parts can I switch over from the Type R to the Civic and what other parts I need to get the motor running in my car? :huh:
  2. NoJokE
    NoJokE Senior Member
    Get the whole suspension and convert to 5-lug. :D
  3. FFCiv
    FFCiv Senior Member
    I not Positive but I'm pretty sure u can't use the engine and if u can it will be a bitch to install. The engine is OBD2 and your Car is OBD1. So if u can't use it u got 0wn3d
  4. E_SolSi
    i have an ITR engine in my 93 .... you just need to change a few plugs on your harness
    its cake
    dont be skured :)
  5. HOOKUPSPROCRX
    HOOKUPSPROCRX Member
    upland ca
    almost everything on that type-r will change over
    motor, suspension, front seat ect. the swap is cake just need to change injectors and distributor to obd1 as well as use a obd1 ecu . if you need somebody to install please feel free to contact my shop 909-373-RACE
