Hello - my first post to hondaswap...
I'd like to swap the D16Y7 in my newly-acquired 99 EJ6 with a B18C5.
From what I have read so far, and assuming that I obtain a 99-00 B18C5, this is what I will need:
- 99-00 Si front tranny mount
- 99-00 Si rear tranny mount
- 99-00 Si driver side mount
- 96-97 del Sol AC bracket (for A/C)
- Integra shift linkage
- 99-00 Si axles
Both my 99 EJ6 and the engine will be OBD2, so no issues there, right?
What about the exhaust, can I use the existing catback exhaust or do I need the Integra exhaust?
How do I wire in the VTEC cables to my existing harness?
Out of curiousity, what else would I need if I were swapping a JDM B18C Spec R instead of a B18C5? a different ECU? if so, which one?
thanks for such an excellent reference.
- 99-00 Si axles
