B18c5 Or Ls/b20/vtec
Discussion in 'Engine Building' started by dvs_prelude, Jan 15, 2003.
  1. dvs_prelude
    dvs_prelude Senior Member
    Sup everyone,
    I was wondering which engine would yield more power fully built for street use? I know the type-R is far more reliable and has a nice crankshaft, but is there much more you can do to it than honda already has?
    How much power can you get out of these engines fully built on pump gas:
    Type-R (JDM and USDM)
    B20/vtec
    LS/vtec
    If I go with the Type-R engine in an EG VX hatch, is it possible to have an 11-12 sec N/A street car?
  2. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    yeah you could have a 12 sec n/a c5'd VX.... very possible, it's still gonna take some building....
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Throw the LSVTEC out of there. It is not worth doing in a Civic. The B18C5 is a better bang for your buck than the LSVTEC. The B20VTEC however is deffinately worth doing in your Civic.
  4. dvs_prelude
    Thanks!
    Anyone know how much power I can get out of a fully built n/a B18C5 and a fully built B20/Vtec? I wanna be able to drive it on the street so I'll probably be keeping the CR around 12:1 or 12:5:1. California sucks with stupid 91 octain premium :(
  5. prawjEKt Cx
    upstate NY
    i mean what the fuck is fully built..... i mean c'mon.....
    http://www.importreview.com
    shitload of dyno sheets to give you an idea
  6. 2 litre EG
    2 litre EG Senior Member
    so cali
    depending on who you have build the motor... then you COULD pull out up to 240+ whp, but like i said depends on who builds it, what fuel system your running, what ECU, etc etc etc... the people over at Import Bulders/ImportReview know their stuff but they can charge an arm and a leg for their dominator/annihilator/killer packages... where in cali do you live... there are a few places i can recommend to you that will give you a good deal if you mention my name
  7. chet
    chet Senior Member
    st petersburg, florida
    b18c5 with jun cams and you're going to make 195-205whp. i'd go with a type r motor simply because its going to be reliable.
    to build a reliable crvtec takes a lot of money and knowledge. and you have to add a breather box...basically honda didn't design the crv block to take high rev's, so you're going against what honda designed and that means sacrificing reliability.
