B18c6 bottom end on to B16a head
kryton
I am currently running an EF9 with standard b series engine. I have been offered a B18c6 bottom end. What will be involed fitting this?
Cheers
the b16 head has a larger combustion chamber. So bolting up the B18 block will seriously reduce the compression; If you'r at it put in P73 pistons to bump the compression to 11.0 and get a type R intake cam. Got yourself a poorman's Type R if u ask me
