im doing a jdm b18cr swap in my 97 civic and there is a ckf sensor on my civic that the jdm does not have do i need to worrie about it any help would be great
No, you really dont need to worry about it, as long as your using the JDM ecu, if your not. You will need to flash your ecu for DOHC anyway, might as well play with sensors! romeditor4 is what you can
All that sensor does is tell you if there is a missfire, it doesn't tell you anything past that.
