b20 142 horse?
Discussion in 'Engine Building' started by jhholloway, May 26, 2010.
  1. jhholloway
    jhholloway New Member
    I know you can't tell how much horse an engine will make without a dyno, but I had my car on a dyno and i was shocked at the results. Here is what I have, tell me if it should have made 142hp i was hoping VERY BEST at 185 but more than 160.
    b20z
    forged pistons 11:1
    crower 403s w/ springs and retainers
    Aem v2 intake
    2 1/4 exhaust (cat delete)
    dc sports type r exhaust manifold (i know they suck, but they were the right price)
    68mm tb
    skunk2 intake man
    rc 370cc injectors
    Aem fuel rail and pressure regulator (i know they don't make hp)
    competition stage 2 clutch
    competition 12lb flywheel
  2. 99sidude
    Ohio
    how are you tuning it?
  3. jhholloway
  4. jhholloway
    it was tuned by matt shue one of the best tuners on the east coat deff the best in VA
  5. Magana559
    Magana559 The Warden
    fresno Ca
    I hit 167 yesterday on a LS with
    nippon 82mm USDM ITR pisons
    JG P&P LS head .5mm OS valves
    Crower 403's
    Ebay short ram
    Ebay ITR replica header
    skunk2 intake mani
    RC 310 injectors
    tuned on crome
  6. phunky.buddha
    Dallas / Fort Worth, TX
    You're leaving a lot of things out...
    How high did you rev?
    Atmospheric conditions?
    Dyno type?
    Air/fuel ratio?
    Aggressiveness of timing?
    Lots of factors...
  7. jhholloway
    yeah we have the same basic build. you have the p and p but that does not give you 25 horse.
  8. jhholloway
    How high did you rev? 7.5k
    Atmospheric conditions? i'm in richmond we are about 32 ft above sea level and it was humid 75 with light showers
    Dyno type? dynojet
    Air/fuel ratio? idk
    Aggressiveness of timing? i had the cams degreed in this morning. then my tuner had to change the time 17 degrees!
  9. Magana559
    fresno Ca
    I hit high for a LS. I hit higher than most, He was surprised that I made that much power.
  10. jhholloway
    the congrats on having a well build engine. I just feel as though mine should be making more than 142 ... stock they are rated at 146. sure that's at the crank but still. the engine is freshly rebuild too. so i was expecting that full 124 whp then I thought all the goodies would have added more than 22 hp.
  11. Magana559
    fresno Ca
    What Intake manifold? What header?
  12. 95EGCoupeVtec
    95EGCoupeVtec SOHC VTEC at its best
    South Mississippi
    a skunk2 intake mani and a dc sport type R replica. it says in the first post lol.
  13. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    that does seem really low... sorry dude. i would think with the high cr and cams would make more than that.
    from what ive seen, bone stock b20s with just boltons (intake, header, test pipe, exhaust) usually makes around 130whp.
  14. Magana559
    fresno Ca
    :doh:
    Try Ebay tri Y header you can get them for $180
    What my tuner said was holding me back
  15. phunky.buddha
    Ignition timing, not cam timing. This is where the power is made on your tune.
  16. 78civic
    78civic Junior Member
    NW MS, Y'all
    Were the cams 'straight up'?
    Advanced or retarded?
    What octane fuel?
    Chipped ECU or stock? (Stock as in B20 or re-mapped 'other')
    O2 sensor good?
    Ported head?
    Is that fuel reg adjustable?
    Injectors-- New or used and flowed? (Or, "Dude, I gots these for sale CHEAP!.. They're _______cc's)
    That does sound kinda low.. Hope my build gets more but won't be dyno'd.
    Too much $$$.
    E
  17. jhholloway
    shell 93 pump gas
    s300
    pretty new OEM o2 sensor
    AEM adjustable fpr
    used RC injectors
    I had the cams degreed, i don't understand what you mean "straight up"
    you'll have to put in on a dyno to tune your build... the dyno was like $80
  18. hondarin
    Texas; where else?
    I would say that seems a little low. I'd be checking spark plugs, injectors, and then I'd do a compression test.
  19. jhholloway
    alright I did a lot of research and found good info. the dyno that I used always reads 5% low. and i was told the wrong numbers. it was 147 not 142 then add the 5% and we made it to .... 155 and that is MUCH more reasonable than 142. when I get a good p&p and a real exhaust set up i should me making 165-170ish that's livable for non vtec
  20. jhholloway
    just for the record I am running the apexi ws2 exhaust. it's only 60mm.
