Have a b16a head on a b20b block, missing bad, compression tests results: 180 150 90 0 ( 1 2 3 4 respectively in honda order) any idea what compression leak could be or next step in diagnosing? Any help appreciated.
i just pulled the valve cover, only thing i can notice irregular was one of the valves on the 3rd cylinder of the exhaust side was a little higher then its pair,
other then that I cannot see anything wrong then again I havent seen many cylinder heads.
