B20 Cams
Discussion in 'Engine Building' started by B18aCRX, Nov 21, 2003.
  1. B18aCRX
    B18aCRX Senior Member
    Central Coast, CA
    I have a b18a and I would like to make sure that i can use B20 cams and see if they are more aggressive than that of a 91 Ls? Thanks
  2. E_SolSi
    they arent (as far as i know)
    get some crowers
  3. sloazcrx
    sloazcrx Senior Member
    You could get a b18b head and put it on your b18a. Slightly more aggressive cams and the head flows a little better, so I hear.
  4. cws13
    cws13 Senior Member
    Athens,GA
    LS cams are put in B20's for a little more power. You already have what you want.
  5. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    just find out which has the most duration, and get the specs on all profiles and then make your initial decision.
  6. pissedoffsol
    b18b and b20b/z cams are the same
    b18a are slightly less
