B20 compatability with D16 question?
Discussion in 'HYBRID -> ED-EF / DA' started by Xemu, Dec 17, 2009.
  1. Xemu
    Xemu New Member
    In the process of doing a B20 vtec swap into my crx. I have a full minime Z6 head with A6 block swap
    And was wondering if there's a list/link somewhere that shows what parts are interchangeable? Both swaps are obd1. Any help would be appreciated,Thanks.
  2. D16SiHatch
    D16SiHatch New Member
    virtually nothing is going to be interchangeable. they are different series engines. the injectors, map sensor, tps, and not much else will be able to switch over.
  3. Briansol
    injectors......
    thats about it.
  4. Xemu
    Xemu New Member
    Thought I heard vtec solenoid could get swapped no? Alternator? Nothing huh. Thanks
  5. Xemu
    Xemu New Member
    Just pulled my Vtec Solenoid off my Z6 Head and bolted right up to my B16A2 head?? Got any other good info?? LOL
  6. Xemu
    Xemu New Member
  7. D16SiHatch
    just because it bolted up doesn't mean its going to work properly. and even if it does who cares? almost nothing else will be interchangeable, so what we said still holds true.
  8. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
