B20 Crx
Discussion in 'HYBRID -> EG-EK / DC' started by C Penner, Feb 28, 2003.
  1. C Penner
    C Penner Junior Member
    Does any one know if a B20 From a 1988 Prelude can accept any VTEC heads and if so does it fit in A CRX with a Hasport kit :rolleyes:
  2. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    No, other then the d17, that b20 is the god forsaken Honda motor. :)
  3. C Penner
    Are you sure I have Read elsewhere on the net that it can be done, would you consider that swap to be A waste then? What about a B21 from A 91' Lude. Can't you swap a B series VTEC head onto any B series block?
  4. Domeskilla
    Fort Wayne, IN
    If you can.. i think ludespeed.com did something like that, but it will cost you WAY more then swapping something "praticle". I would consider it a waste b/c there is so much easier stuff to get into the car and that have more aftermarket support. Want a 2.0 so much with vtec. Bore a b18 or go cr/vtec. You can ressearch it, but they dont have any/much aftermarket support.
  5. C Penner
    I paid $400 Canadian for the b20
  6. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    here is the b20a5 vtec article:
    http://ludespeed.com/products/prelude/articles/vtec/
    and i do not think that the prelude b20 will fit in a crx, or at least not easily... HASport mount kit will not fit the b20 from a prelude. if you want a b20 that will fit make sure it is a b20 from a CRV.
