B20 help
Discussion in 'HYBRID -> EG-EK / DC' started by HondaSickness, Mar 3, 2009.
  1. HondaSickness
    HondaSickness New Member
    SL,UT
    i currently have a have a B16A with LS tranny & PCT-J11 ecu in my 2000 civic coupe. my bro just gave me a B20 long block & told me to take what i need from the b16 to get it running. not really about this stuff so take it easy on me please, the b20 with ls tranny, can i use the axles from the b16, what about mounts can i use the stock si ones that are already in my car & what ecu will i need? i feel like im leaving lots of stuff out just to get it running please what it is. need it running within the week really bad not sure why hes making me down grade & he never helps sigh...:confused:
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    all you need is the block, if you are already running a b16 just use the axles, mounts and ecu from that
  3. HondaSickness
    SL,UT
    so its fine to run the ctr ecu on a none vtec motor?
  4. AHHVTEC
    Alabama
    if you put the b16a head on it. it will be vtec
  5. HondaSickness
    SL,UT
    O i dont get to keep the head...
  6. AHHVTEC
    Alabama
    then if your just gonna run the b20, you need a new intake manifold and ecu.
  7. HondaSickness
    SL,UT
    ok thanks for your help:)
