b20 in a ef
cb7killa
So my friends d series took a shit on him. So we found a DA integra with a built b20. My question is what parts can we use off the car to make the swap work in his. We already have hasport ef b series mounts and shift linkage. The car is still dual point so I will have to convert to multi point and my question there is can I use the da ecu and wiring and what not.
And if there is a sticky about the swap can someone post a link for the b20 or can I use the b16 swap guide.
Thanks for your help.
if your in the same spot as me your gonna have to change your spindles as well. take them right from the da. good luck bro
So any update got the motor in and running but when its in nuteral it idels fine but when you put it in gear it runns funny acts like it kinda wants to die. The tranny is a s1 if it helps any.
