B20 Into 5th Gen Hatch
bush20
im installing a b20b into a 93 civic cx. the cx only has one wire going to the o2 the ecu needs a four wire. how do i do the conversion? also i have a integra ls harness, would that work?
yes you can use your LS harness, the CX O2 sensor has been covered do a search and it should come up.
