b20 into 90 integra
Discussion in 'HYBRID -> ED-EF / DA' started by marek, Aug 9, 2005.
  1. marek
    marek Junior Member
    would a jdmb20 swap into a 1990 ls teg be a hard swap and what would be the components that i would need to get. can i use the same tranny?
  2. formby
    formby learning in progress
    its a staight foward swap....but it could be hard for you.....
    just remove the old engine...reuse the original teg harness...put in the new one.....and use the ls tranny
    btw what year is the b20
  3. brian11to1
    brian11to1 Senior Member
    use hte mounts nad brackets from the old engine. use the alternator from the old engine, use the crank pulley from the old engine. if its a b20b w/8.8: cr and you use the pr4 its going to run rich. if its the 9.6:1 b20z its going to run lean. so you need to get something to change fuel maps. SAFC, turboedit, whatever.
    ive done this swap, so let me know if you need help
  4. The_B_Sleeper
    The_B_Sleeper Junior Member
    i just picked up a b20z and now i wait for some custom aris pistons... :worthy:
  5. drpenguin
    drpenguin Senior Member
    Salem, Or
    :withstupid: I guess you could call it a swap. its more like in and out. you dont have to change your mounts, rig up some wiring, or any of the fun stuff. I mean come on man give us a harder task then this. :blink:
  6. brian11to1
    acutally, you cant use the stock mounts on teh engine, you need the integras b18a mounts...
    but yea, its pretty much a direct replacement.
    also keep the intake and exhuast manifolds off the LS engine.
  7. DirtyRice
    DirtyRice Junior Member
    if you fuck with a b20 and you dont plan to go vtec GET A BLOX INTAKE MANIFOLD! its good for the b20 being that they dont like to make power past like 5500 rpm. that manifold will let you breath up to 7250 stock and pull good all the way up!
    -DirtyRice-
    !!!Got to my website and get my newest album free!!!
    [​IMG] [​IMG]
