b20 into 91 crx si
Discussion in 'HYBRID -> ED-EF / DA' started by 91crxb20, May 4, 2004.
  1. 91crxb20
    91crxb20 Junior Member
    im really wanted to do this and im going to i kno its possible but i really dont kno everything i have to get.......so far i got:
    b16 tranny
    Hasport mounts
    shift linkage fir b16
    i really want to kno what wiring i will have to do for it to get mounted and everything if sum one knos could you please help me out thanks......
    Chris
  2. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    me = tard
  3. turboB20hatch
    turboB20hatch Senior Member
    pacific nw
    hes doing a b20 swap so he will have to run ZERO wires for vtec
  4. jdmvteccrx
    jdmvteccrx Member
    turbob20hatch you are not allowed to speak. ;)
    it wouldn't be crazy for one to assume he had a vtec b16 head when he has
    b16 tranny
    shift linkage fir b16...
    what head will you be running?
  5. turboB20hatch
    pacific nw
    stfu.. no where did he imply that the b20 had vtec
    :kick: :kick:
  6. Citizen_Insane
    Minneapolis
    GOD DAMNIT!!!
    For once turbob20 is right and jdmvteccrx you are being a stupid n00b. You cant even speak english. No shit he would run a b16 SL if he has a b16 fucking tranny. And having a b16 tranny has nothing to do with VTEC.
    I'm retarded. I just assumed that you were running a CRVTEC...and I just wasn't thinking. Sorry, forget my previous post. You will have to convert to OBD2, so either rewire everything or get a conversion harness for $150. (I think its OBD2, but it might be OBD1 depending on the engine...i think all b20s are OBD2). Also, dont get the b20a, get either a b20z (the ideal) or b20b(?). Sorry for the missinformation ealier, i wasnt thinking.
  7. turboB20hatch
    pacific nw
    :withstupid: :werd: all b20b's and all b20z's are obd2.. and what do u mean for once ??? im always right :p
  8. brian11to1
    brian11to1 Senior Member
    TO save some trouble wire the engine OBD0 using OBD-0 Harness w/injectos, ECU, Distributer and install a set of Stock LS cams any year 93+ are better then the uber ghey B20 cams. Use a 92-93 LS header and 90-91 LS IM . Hope this was straight forward adn to the point, yet truthful and non-misleading.
    Also make sure hte "B16" trans is Cable not Hydro. If you need a cable I have an S1 I'll sell cheap, I paid $200 I'll sell for $200 plus shipping. No grinds, mad clean, has just about 98K miles.
  9. turboB20hatch
    pacific nw
    very very good straightforward advice...
    the b20 cams do suck
  10. brian11to1
    Thank you man!
