B20 INTO 92 DX HATCH
Discussion in 'HYBRID -> EG-EK / DC' started by SPEEDFREAK0920, Mar 28, 2004.
  1. SPEEDFREAK0920
    SPEEDFREAK0920 Senior Member
    chI-t0wn fo0
    I NEED SOME HELP REALLY BAD. COULD ANY1 GIVE ME SOME INFO. ON A B20 SWAP INTO A 92 HATCH? WOULD IT BE A DIRECT BOLT IN? WOULD I BE ABLE TO USE THE B20 TRANNY IF I'M PLANNING ON DOING A VTEC HEAD LATER ON? AND WOULD I NEED NEW AXLES TO SUPPORT THE EXTRA WEIGHT? HHHHHHEEELLLPPPPPPPPPP!!! PLEASE IM IN NEED
  2. hybrid89
    hybrid89 thistownsucks...
    SoCal
    all that I can help with is..
    1. I know the tranny is crap as far as being strong.very weak tranny
    2. It should fit, no hugh difference between a B20 block and say a GSR os LS swap. I should easily be done.
    matt
  3. MXDesa
    MXDesa Senior Member
    Queens, New York
    I dont believe you will be able to use the transmission because the B20 is out of a CRV and the tranny is designed for a all wheel drive set up.
  4. phunky.buddha
    Dallas / Fort Worth, TX
    IT CAN BE A DIRECT BOLT IN IF YOU USE THE PROPER OEM MOUNTS. YOU CAN SHOULD USE AN INTEGRA TRANSMISSION FOR THE B20 BLOCK. THE GSR OR TYPE R IS A GOOD CHOICE FOR THE B20, ESPECIALLY IF YOU'RE GOING TO GO ALL MOTOR ON THE ENGINE BUILD. YES, YOU NEED NEW AXLES BECAUSE YOU'RE GOING TO USE A COMPLETELY DIFFERENT KIND OF TRANSMISSION. B SERIES USE INTERMEDIATE SHAFTS AND EQUAL LENGTH AXLES, THE D SERIES THAT CAME IN YOUR HATCH DOES NOT.
    NEXT TIME YOU'RE IN NEED, TURN OFF THE CAPS LOCK AND TYPE IN PARAGRAPHS... THAT MAKES YOUR QUESTION A LOT EASIER TO READ AND YOU'RE MORE LIKELY TO GET DECENT RESPONSES.
    :p
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    WHAT'S ALL THIS RUKUS IN HERE?!!??!?! YOU KIDS STOP ALL THE YELLING, AND SCREAMING!!!!
    :p
  6. 90crxb18
    90crxb18 Senior Member
    lake elsinore cali
    im pretty sure you will need a new IM also the one from the B20 sits too high i belive.
  7. xj0hnx
    C.C.TX.
    Yes the giraffe style intake manifold needs to be replaced with a LS one.
  8. phunky.buddha
    AAAAAAAAAAAHHHHHHHHHHHHHHHH!!!!!!!!!!!
    :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
