well got a buddy with obd1 b20 block with obd1 ls head and tranny...buddy finished swap, car cranks but doesnt start up...everything has been double checked..no CEL,looks like we got fuel..new pump,filter,injectors and plenty of fuel coming out clean...and pulled out plugs and saw good spark.....good compression...maybe coil in distributor bad? the thing is when we first swapped and started it up...it started up...but the car would rev up a bit to mabye 3-4 rpm then drop back to 1 then check engine would come on and flicker on and off and on and off..then would rev up again and would repeat this for a while...so we turned it off...then came back to start it up the next day and it wont start up anymore..only cranks..any advice?
