B20 Question
bccivic
Hey guys, I have the stock b18b ls motor in my integra right now, and im thinkin of swapin motors to a b20b. I was wondering how well the stock motor will hold up for turbo, running around 6-7 psi? And would I be able to use all my ls components such as a/c, ps, and such on the b20?
Thanks
for low boost on a smaller turbo you should be fine (with tuning)
and yes you can use all of your components
you need to use your IM too
you could but the fuel maps wont be quite right
Well if I am running FI, then I would run high flow injectors, with a vafc probably and go from there, but in the meantime I could use the b20 ecu?
You could use the B20 ECU, but it's for an automatic and will throw codes bitching about not having an auto hooked up to it. I would use either your stock ECU and a VAFC / SAFC or get a Hondata chip.
