b20 question
Discussion in 'Engine Building' started by mmk21, Sep 8, 2005.
  1. mmk21
    mmk21 Junior Member
    I plan on doing a b20 vtec with a gsr head. I'm going to put forged pistons and rods. Try to get as high a compression as possible. Head is fully built too with stage 2 cams, port and polish and everything.
    I just wanted to know how much power the b20 can handle and will i need to resleeve the block?
  2. reikoshea
    Dallas, TX
    Well a dart B20 can hold about 650 (Stroker Kit, Bored out, Cams, PnP, New Head, Turbo) Now the Aluminum B20...thats another Story. I would say 400 might be pushing it, but i really dont know
    But yes, you will have to resleeve the block or go with a Dart block (cast iron. http://www.dartheads.com)
  3. brian11to1
    brian11to1 Senior Member
    resleeve it now, save yourself the headache.
  4. phunky.buddha
    Dallas / Fort Worth, TX
    If you're staying all motor, there's no need to resleeve the block. You can run upwards of 250whp with good tuning without worrying about the sleeve.
