b20 questions
Discussion in 'HYBRID -> EG-EK / DC' started by he||raiser, May 9, 2008.
  1. he||raiser
    he||raiser New Member
    I've been researching swaps for a while, and I still have a couple of questions regarding swapping a 2001 usdm b20 into a 96 civic ex:
    1) If I use a 99-00 si header or aftermarket equivalent, will it fit with the 1996 ex cat without modification? I was thinking length should fit, but maybe the flange would be different.
    2) If I use a hydro gsr tranny, does the clutch I get need to match the b20 engine or gsr tranny? I take it the b20 and b18b are similar, so could you also get the clutch to be compatible with the b18b?
    thanks guys.
  2. IanB
    IanB MB4 X2
    2) All hydro B-series clutches are the same.
  3. he||raiser
    ok, so does that mean that any b-series clutch will fit a gsr / type r / ls tranny??
    anybody??
  4. IanB
    IanB MB4 X2
    That's what it means, as long as you keep cable vs. hydro together.
