B20 Questions
darwins_vtech
Hey, I got a 93 coupe w/ B16. I am going to go B20 -vtec. But what do I all need. I think I need the block, breather kit, head needs to be drilled/tapped-from B16, tranny from B16, and then my axles and shift linkage will work, and What mounts do I need, what header, and intake manifold work best? I want to do some bolt ons too, like intake mani, header, fuel rail,injectors, fuel regulator..... any body have answers? thanks
Darin
You can use 94+ ls mounts or the mounts you have on the b16, you don't need an intake manifold unless your going to have forced induction, as for the header just get an ebay one...fuel rail,injectors, and fuel regulator-unecassary
