b20 swap help..
b20bswap
hi,
I am new to swaps and need some info. Any help would be appreciated.
I wanted to know if a b20b will work with a 91 integra Ls transmmision?
I have read that I will need a Ls starter too other than the intake and ECU.
Will the axles, ECU and mounts out of a 91 integra work? or do I need different ones?
The parts I will need for the swap that I can recall are: (excluding motor & tranny)
Mounts
Axels
ECU
Intake manifold
Shift linkage
LS starter?
Wiring harness
Pls let me know if I am missing anything.
I will appreciate your help.
Thanks
thanks alot for the info.
Will the mounts out of a 91 teg work?
the 91 teg tranny will work but it a cable and your civic is a hydro. so you can get a kit to run the cable tranny or find a hydro one. also you need the 99-00 civic si rear mount and timming belt mount. good luck
