b20 turbo
Discussion in 'HYBRID -> EG-EK / DC' started by rickshaw racer, Jan 30, 2009.
  1. rickshaw racer
    rickshaw racer New Member
    middle of nowhere
    roughly how much boost will stock internals take, for (safe) DD? planning on b16 head swap at later date.
  2. get_nick
    Washington State
    130psi
    do you know much about turbos?
  3. rickshaw racer
    middle of nowhere
    looking for roughly 6-8lbs boost, without changing pistons and rings or cams, wanna spend that later with b16 head.
  4. George777
    George777 ^^ Likes Bewbies
    With your mom
    Why don't you just wait until you are ready to do the vtec conversion to boost it?
    Stock sleeves on the B20 suck.
  5. get_nick
    Washington State
    you still didn't answer my question.
  6. rickshaw racer
    middle of nowhere
    looking to get turbo set up and was curious, found a good head w/stage 2 cams for 500$
  7. get_nick
    Washington State
    alright guy, you're on your own on this one.
  8. ItsBigT
    ItsBigT New Member
    Richmond, Va
    no b20 block is a low comp. block atleast 10lbs my friend has a stock b16 on 10 lbs and is hold up real good
  9. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    yeah it might hold up 10 if its tuned really well. but dont be revving it to 8000+ rpms.
  10. austin20110
    austin20110 New Member
    Northern Va
    you will be lucky to get 5 psi out of that block, for more than 10 passes like george said the b20 sleeves suck
  11. George777
    With your mom
    Based on the research I have done, the stock sleeves on a B20 will only hold about 4-6psi from a T4 60 trim turbo with a modest tune. Granted, these numbers can be used loosely as you see fit, but if you plan to make any kind of power out of that motor, at the very least you need to resleeve it.
  12. FLounder
    :disgust1:
    if you replace the rods, rod bolts, and pistons and its tuned well they can take some boost. there are plenty of people making 300hp on stock sleeve b20s. i know of one that makes over 400whp with stock sleeves, and for 6 months and counting.
  13. austin20110
    Northern Va
    but he said STOCK.. .stock means stock to me
  14. FLounder
    you guys keep talking about the sleeves....
    from all the research i have done and from what ive personally seen, the weak link is the rod bolts. the stock sleeves are prone to getting hot becuase they are thin, but if the engine is tuned well they can handle a bit of pressure.
    this subject interests me a lot because i am currently planning a build of my b20z bottom end :D
  15. rickshaw racer
    middle of nowhere
    Thanks guys. Wasn't planning on a 10 sec. Drag car. Just a fun DD, that will still smog.
  16. Matts96HB
    Matts96HB . Moderator VIP
    Boo.
    Boo.
    Boo.
    How many times must I say this? PSI is completely irrelevant UNTIL you select a turbo size. I wish everyone on this board would understand that. It'd solve a lot of problems more quickly.
    To the OP: Stock B20 internals would make me nervous above 200whp especially if it is a DD. Build it right, or don't do it at all.
  17. George777
    With your mom
    I selected a turbo size/trim, and did a little research... :ph34r:
  18. Matts96HB
    I saw that your post actually made sense. One of the few in this thread that did. Well done :thumbsup:
  19. rickshaw racer
    middle of nowhere
    that was just my point.v dont really have a need for more than 200hp, damn speed cameras get you if your 10mph over posted, gets exspensive having a lead foot.
  20. Matts96HB
    You should be alright on stock internals then. Has the bottom end ever been opened up?
