B20 vtec + 12.1 cr + Hondata + 240cc injectors
khai_tuan_nguyen
I have a b20b with b16 vtec head and 12 cr. I will be dynotuning with hondata so do I still need to upgrade injectors or can hondata compensate for it? I was planning on using stock injectors? Is it really necessary? I have ctr valvetrain and revving to only 8k. I am using walbro 255lph and aem fpr and fuel rail
Khai
theres a good chance you might run out of fuel up top-- just watch the a/f towards 6k and up.
i'd go with 370's personally....
How hard are they to take out and put in. I am basically worrying about emissions and dmv and having to swap things out and in. For now all i have to worry about is a test pipe and ecu.
KHai
to swap out injectors? easy man..
and i'd go with 440's
Originally posted by khai_tuan_nguyen@Aug 16 2004, 07:16 PM
How did it run Calesta? Good enough? I have an aem fpr.
Khai
[post=377660]Quoted post[/post]​
Yup, good enough- same power curves and same a/f ratios as when I switched to 310cc injectors.
