b20 vtec crv???????????
Discussion in 'Trucks and SUV's' started by Seany-izzle, Feb 24, 2007.
  1. Seany-izzle
    Seany-izzle New Member
    In a fucking house.
    Well in my quest for a new vehicle I always had the thought of getting a CRV. My parents had a 97 and I really liked it. the only real problem was the lack of power, my mom had the automatic (probably the first problem) and it struggled to get up steep hills. Friends mom had a manual and it wasnt AS bad but still chored to get up big hills. Well i dont like any of the 02+ ones, and all the ones i can find around here are in the 90k+ range. Here's where i got to thinkin... b20 longblocks are stupid cheap, 750 bucks. How could i get more power with it? Well nothing much w/o headwork and some cams. Then i said to myself "b20 vtec". blah blah b20 vtecs arent reliable, only if you dont do it right
    quick parts list i came up with..
    b16 head, im, dist, ecu
    gsr oil pump, t belt, water pump
    arp head studs
    ge vtec kit
    fpr, high flow pump
    some sort of header (itr or dc knock off)
    hks sport exhaust?? only thing i can find, 60mm piping
    thats pretty much it, im not gonna get into switching out pistons, valve springs, cams, etc. So its a pretty basic b20 vtec. Pretty much the only thing that has me questioning this is the strength of the crv axles and ds. I mean, the power wont be that high, maybe around 170hp/140tq tuned (unless im totally off here..) and what i really want is tq and low-mid power, f top end :p Plus its not like im trying to make a beast, obviously :)
    Sooo i guess im asking if the crv could handle it and is the b20 vtec pretty much a bolt on affair? Keeping the complete b20z bottom end and simply just slappin on a b16 complete head with i/h/e. I think i'd be very happy with it, a crv with some more pep and no struggle to get up hills andstill quiet enough and smooth enough to drive every day.^_^
    Anyone got opinions, advice, suggestions, critisizm, etc??
  2. 97hatch
    97hatch ?
    Anderson IN
    do it ive wanted to do a boosted one for a long time but never have come across a good deal on one. and about a ls vtec not being reliable this is my statement. i ran ab20b with a b16 head and itbs for a bout 35k and never had a problem and i never did the water pump or pil pump i never reved it over 8200 and it seamed to be all good when i pullled it out two weeks ago to build it. i drove the car from texas to indiana twice and never had a problem. you also have the option of buying a bisi trany adapter and runing a h22 or a h23 that would be a cool swap.
  3. Seany-izzle
    In a fucking house.
    an h22 swap would be cool, i looked briefly and couldnt find any mounts, plus the b20 route is cheaper :p I can find crv's for like 6k all day long up here, add the cost of the motor and vtec head (plus the goodies) im only lookin at about another 3-3.5 grand with a header and exhaust. Only thing is, i dont want it to make much noise (hence the hks sport, plus its the only one i can find), anyone know the stock exhaust dia?
  4. CRXSi86
    CRXSi86 Fatty
    Brunswick, OH
    i dont think you should worry about the axles, there basically the same as LS axles, not the rear thoguh, rears are pencil thin, but my buddy has an LS-T with 250 whp and 250 lb-ft torque, his axles are fine. i think you should be alright, but im not 100% sure
  5. Seany-izzle
    In a fucking house.
    are they the same axles?? Im just not sure because i imagine they are longer and im pretty sure the ends are different. When i asked this i totally forgot honda awd is like what... 85/15 or 90/10.
    What i listed is all i need right? Should i get a odb1 ecu (p72?) and a harness then have it tuned or just run the gsr ecu (atleast until that money comes available)?
  6. Seany-izzle
    In a fucking house.
    damn, i ball park priced everything.. god damn!
    b16 head 500
    arp headstuds 130
    p72 200
    obd1-2 harness 130
    knock senson 25
    97+ lude injectors 150
    fpr 100
    im gasket 50
    fuel pump 75
    ge vtec kit 200
    dc header 300
    hks exhaust 525
    tuning 150
    total 2435 not including shipping on the parts plus the cost of a shipped motor and new waterpump/timing belt (1k) = 3500 and not even a new trans or axles!! Thats quite a bit more than i expected, or do i have unnecessary parts/off prices?
  7. 97hatch
    97hatch ?
    Anderson IN
    it can be done cheeper you dont need biger injectors or pump and you could just drill the head with a 14mm drill to relocate the dowels buy the fittings to run oil to the head from the oil pressure sending unit spot ( pm me for a list of fittings and such) you probaly dont need the fpr i think you can get a obd2-obd1 cheaper than that i think thas all the in put i have right now
  8. pissedoffsol
    you'd want a p30 (no iab control) or even better, a chipped p28 and throw out the knock crap. stock 240cc injectors will support the crvtec powerlevel (assuming stock internals)
    the stock rail has a FPR on it. no need for a new one
    the fuel pump is also fine.
    so i think you can shave off some cost
  9. hazzardboy95
    hazzardboy95 Hon-daaaa
    Pasadena, Md
    This thing sounds pretty bad ass, the weak spot on the b20's is the thin cylinder walls isnt it?
  10. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    90/10 so don't worry about the rear axles
    if you find 84mm pistons for with higher compression you could have something pretty fun to drive. but if you don't want to fool with the bottom end, then it still should be fun. thing about vtec is it's all top end as you know so you'll have to be sure to consider implications of revving to 8200rpm
  11. sirmerced
    sirmerced New Member
    So what trans are you using? I have an auto, and have found no place that would properly prep an auto for 200hp.
  12. lewellgd
    lewellgd 92CivicHatchCxBORNINCALI
    I can get you h22 with 90,000 miles with axles motor shift linkages any thing u need for like 1700 bucks just try to find mount kit and let me no.
    I have the hole car that is totaled it was hit in the rear. Engine is strong.
  13. SHOGUNOVDDRK
    SHOGUNOVDDRK New Member
    australia
    do it...i too always flirted with doing one up but price is way outta ma range...
  14. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    I know this thread is old.
    Anyone ever flirt with the idea of an H2B into one?
    Or even just fabricating a turbo setup.
