B20/vtec into 86 CRX SI
Discussion in 'HYBRID -> ED-EF / DA' started by CRXSi86, Jan 8, 2007.
  1. CRXSi86
    CRXSi86 Fatty
    Brunswick, OH
    hey guys, im buying a B20b block with a b16 head, ecu, vtec harness... i know i will need the axles hub and brakes, engine harness, shift linkage, and mounts, and the main and rod bolts and head studs, anyways,....
    is this a real complicated swap, what else will i need to do, im trying to find out all the info i need, i also need a tranny, if you guys know what kinda tranny fits best or is the best for this, that would be great, thanks
  2. CRXSi86
    CRXSi86 Fatty
    Brunswick, OH
    Anyone???
  3. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Transmission- B16 has the best gearing, plus it's cable actuated.
    Needed to roll- Axles, Mounts, Shift Linkage
    Needed to drive- harness that will work(don't know much about 1st gens), obd-0 to obd-1 jumper harness for the ECU (if you want tunability and VTEC).
    Should get you started anyway.
    I don't know if this is a bolt in process or what, but like I said, I'm not really familiar with 1st gen swaps
  4. CRXSi86
    CRXSi86 Fatty
    Brunswick, OH
    yeh im bringing my harness to rywire.com, and they will do the full conversion for me to OBD1 for a plug and play harness. im not sure what ecu i should get, i know i need something that will be chippable to dump enough fuel, but thanks for your help,
    if anyone else knows anything, it would be greatly appreciated. :)
  5. Andrew
    Tallahassee, FL
    you won't be disappointed with Rywire's work!
  6. CRXSi86
    CRXSi86 Fatty
    Brunswick, OH
    yeh thats what i have heard, and i think im getting the 93 GSR YS1 tranny a OBD1 P72 ECU with hondata s100. im also getting ARP studs and bolts. so im wicked pumped
  7. 91sirex
    91sirex New Member
    91 crx
    hey i have a 91 crx si with a b18a1 in it im thinkin of either putting a b16a2 in it or i found someone that i can possibly get a b20 with a b16a2 head what would i have to change in order to put either one of those engines in my car i like the b18a1 engine its quick in my little crx i have beat everything put against it but i want to build something myself. instead of keep something someone else swapped
  8. eg6sir
    awesome first post BTW!! :ph34r:
