B20/vtec Vs. Ls/vtec
Discussion in 'Engine Building' started by performanceconcepts, Apr 7, 2003.
  1. performanceconcepts
    performanceconcepts Junior Member
    so...
    is there a measureable horsepower advantage in building a cr/vtec, as compared to an ls/vtec? or, is the torque increase the only major advantage?
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    horsepower is the measure of torque at a certain rpm. it all depends on where you want to make your torque.
  3. performanceconcepts
    so, has anybody seen any dyno sheets comparing the two? i need to know if it will be worth the extra cash to build the B20
  4. phunky.buddha
    Dallas / Fort Worth, TX
    More displacement = more torque = more horsepower. Every custom build is different... but built equally, the larger displacement engine should put out more power.l
