B20.vtec whp, off by alot???
Discussion in 'Engine Building' started by 2slowcivic, May 30, 2004.
  1. 2slowcivic
    2slowcivic Junior Member
    OK I been told B20B with a B16 vtec head would push out about 160-170whp, now my first choice was the almost common B16A1 swap, but I been told it does 140whp. Can anyone give me a more accurate #'s on a B20B w/B16 head?
  2. turboB20hatch
    turboB20hatch Senior Member
    pacific nw
    :rolleyes: :readfaq:
  3. 2slowcivic
    I will do! thank you nice sign!
  4. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    depending on the build it could produce much higher numbers 220 whp , but come up with a goal.. see if it fits your budget.. do it... then dyno it and tell us how much whp pyou made
  5. artyk
    artyk Junior Member
    I just got my car back 2 weeks ago after doing the b20 coversion with the b16 head.
    I got 124 KW or i think 165 HP at the wheels at 7200RPM (will test again till 7800)
    (dont know if the aussie hp is different from the US)
    running a b20b
    b16 head
    port and polish intake and exhaust
    Toda spec A cams
    toda cam gears
    integra type r exhaust manifold modified
    2.5" exhaust
    toda springs and oil pump
    lighttened flywheel
    hondata
    CAI
    hope this helps
  6. phunky.buddha
    Dallas / Fort Worth, TX
    You should be pushing much more power than that... maybe 200-210 with that setup. Australian HP will be the same as American HP.
  7. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    dude, dunkin donuts owns
  8. phunky.buddha
    What the hell?! :wtf2: :newbie:
