B20 Wagovan Sleeper
klyph
Dismember
VIP
Wasn't sure where to post this.
There's pics and mods at the bottom of the page
What is and what should never be (for sale) - hybrids.jp
Can you say sleeper? :sleep:
There was a track-prepped wagovan on ebay some months ago. I'd love to go walk on people in a car that looks like a shoe for the formatively handicapped.
Sweet... heres what the seller posted in that link(for all you lazy people...
seller said:
Engine/Trans:
JDM B20B longblock
HASport engine mounts
New rear trans bracket
New timing belt, tensioner, and water pump
HASport OBD1 conversion harnesses
P75 intake manifold
P75 ECU
New IACV and ECT
New intake manifold gasket
New radiator, thermostat, and radiator hoses
New alternator
B16A crank pulley
Generic 3" intake painted black
RS*R 4-2-1 header with 2.5" collector
New 2.5" Magnaflow cat
New 2.25" exhaust with Magnaflow resonator and Dynomax muffler
New SK7 throttle cable
Custom JDM Sapporo coolant reservoir
YS1 trans (rebuilt)
Clutch Specialties clutch and pressure plate
Lightened and balanced B16A flywheel
HASport shift linkage
Energy Suspension shifter bushings
Rebuilt axles
Hawker Odyssey Battery
Suspension:
Omni Power coilovers (12k/10k)
91 Civic EX knuckles (powdercoated black)
New ARP wheel studs
New front wheel bearings
New lower balljoints
New tie rod ends
SPC rear camber adjusters
Rebuilt original steering rack
Suspension Techniques sway bars (not installed)
Brakes:
New 91 Civic EX 15/16" master cylinder and 9" booster
Rebuilt 96 GSR calipers
Hawk HP pads
New Russell ss braided brake lines
New brake light switch
Interior:
Nardi 360mm steering wheel
Momo hub and aluminum spacer
JDM cupholder
Astroturf floormats
Circuit Hero shifter extension
Razo metal shifty knob
Exterior:
Sweet WAGOVAN custom plate (CA only, I have OR plates on it now)
Hybrids.jp plate frames
Plenty of stickers to make you look like all the other ricers
That baby needs a wire tuck... and a b16 head......
