B20
RE101
Can anyone give me physical measurements of this engine? thanks in advance!
good info but no dimensions lol
anyone else?
yes please i have a project im thinking of putting this into but need to make sure it will fit. thanks
What B20 are you referring too? The one from the CRV or the one from the Prelude?
I don't have the dimensions, I'm not sure that's info you'll have much luck finding, but they are identical to a B18b if that helps at all, only difference being the intake and exhaust manifolds that come on the engines. Also VERY similar to any other B-series except the B16 due to the lower deck height.
A B20b or B20z has is the same size wise as a B18. The intake manifold is taller thats all so it wont clear the hood on a civic or integra. You will need to use a B18b intake manifold.
