b20a engine
Discussion in 'Accord' started by yardeman, Nov 9, 2007.
  1. yardeman
    yardeman New Member
    hi guys' need your help on an engine swap.. can the b20a eng it has pgm-fi . fit in my 1994 honda accord ex.... will the eng mount line back up thanks
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    no you will have to mod it alot to get it to work, your stock motor has better power
  3. snoopyloopy
    snoopyloopy New Member
    Killa Cali
    if he means the usdm prelude b20a5, then yes, his stock has = or more power. but if he means jdm b20a from 2g prelude/3g accord, it has more power than his stock engine. however, either one is a pain and there's other options that will warrant more power for less money and headache.
  4. AHHVTEC
    Alabama
    the b20a from the 3rd gen has 160hp the stock f22 has 145hp,.but the f22 has more torque if im remember correct, so it wouldnt be woth it to me
  5. yardeman
    yardeman New Member
    thanks guys..can the manual tranny work in my car without mount adjustments its from a jdm prelude its from the above mention b20b eng
  6. AHHVTEC
    Alabama
    no
  7. norcalgsr
    NorCal
    And there is also basically no way to fit either of those B20's into a 94 Accord without custom mounts & mods.. so like everybody already mentioned don't bother trying to do it.
  8. USDM CRX DX-R
    USDM CRX DX-R New Member
    If you want a cheap DOHC motor, go for an H23A. It WILL drop into your Accord, bolt right up to your transmission, and produce more power and torque than either the B20A or the stock F22 (160HP, 156ft-lb torque). The H23 is also relatively reasonably priced.
