B20B intakes
Delsolcrazy
will an LS intake off of a 90 ls work with my 97 b20 or do I have to run a 94 and up one??
[post=426474]Quoted post[/post]​
you should be able to use the 90 intake becouse thats what you will need to run four your 90 ecm... b serries should all fit
Originally posted by brian11to1@Dec 5 2004, 04:48 PM
What year is your car?
[post=426602]Quoted post[/post]​
Its a 95 del sol with a P06 ecu. I have chipped the P06 ecu and will be running uberdata.
every thing is in the build of the motor & what you have put into it /phoenix depending on your friends setup and fuel management hes fine-dosnt matter if its a b20b or b20z really one has more horse & toque is all- but both have the same weaknesses- ur b18a1 is probably shot and would require more than 1000 to fix - 1000 in parts -2000 in labor to have that shop install those parts
